ZenUser218NMGPD
Could you tell us a little more about your case?
- When did you receive/put the battery into use?
- How long have you been using the battery?
I would also like to compare the serial numbers of the damaged devices. At best, these are close to each other, which could possibly indicate a defective batch.
In our cases, these were the following serial numbers:
As you can see, the serial numbers of our inverters differ by only 39.
Incident 1:
Inverter: HOA1NAN9N385XXX
Battery: FO4NHN4N4103XXX
Incident 2:
