Good afternoon. Help me to understand the problem that I have with my zendure superbase pro 1500. The problem is that during the operation of the station with the solar panel and AC & DC turned on at the same time, the station first shows that there is an error and then restarts indicating that it has overheated. But in fact, it is not. It is cold and not overheated. The input power from the panel is 120 watts, AC - 70 watts, DC - 35 watts. If you turn something off, everything works normally. If the charging is done via the 220-volt network, everything is also fine. The error occurs only in this combination. If you turn on AC and DC but load only one output, everything works as well. Can you help me figure out if this is a software defect or if something is broken?
