There are 2 things to check: 1. Check that the battery cells are calibrated. Charge to full till it stops by itself,do not charging yourself when it reaches 100%. The SOC must be calibrated. 2. What devices do you have connected to it? With AC on (and no devices connected) you will use about 1.5% per hour.
