I have two SBV6400 units connected to my home panel via the zen ports. One of them will go into off-grid mode, which is need for battery backups. The other will start to go into the mode, click a couple of times and give up. To make things worse, when only one SBV 6400 is connected, off-grid mode only allows me to use half of my circuits on the home panel for some reason, making the whole system useless unless I can get the second unit to go into off-grid mode.
Zendure customer support is insanely slow, so not much help there.
I have tried resetting the SBV6400, but results are the same. Does anyone know how to fix this?
