You'd use the output of the SBV to power your loads through your panel. While the SBV is isolated from the grid, it doesn't really matter which pin of the plug is used as live vs. neutral, however with the SBV in UPS mode you could end up shorting the input power if you get it wrong, so that's the mode that you need to figure out which pin is which.
