Today there were new firmware and app versions available for the SBV.
If you update the master firmware you can now set the lower limit for discharging the battery. And then you are able to update the SBV with your smartphone when you're connected by bluetooth to the SBV. This worked fine so that I don't have to run my router without an UPS. I plugged now the router to the SBV, too.
