21232f297a57a5a743894a0e4a801fc3 I have the same issue. I took little screws to fix the cover with the rubber bands. I don't know how to upload a picture.
sebastianotley@gmail.com Mine too on the UK version; not sure it needs the cover but might glue and screw one day.
rex for my use case, the cover was in the way and I removed it. you should be able to glue it back, but take care in which type of glue you use.
israndy I had the one unit have the AC door fall off cleanly, would kinda like it if the same happened on the other unit, oh and on the AC input
kjlennon Yep, happened to me too kuk versionl, top hinge as well. I've tried gluing, but it's very fiddly.
