utlize So I put a full size refrigerator on the super base v. Turn on the AC mode and the unit automatically shut down. It reboots and shuts down again. I'm guess the unit cann handle any kind of draw of power?
utlize I put it into ev mode and plugged power. It worked . Although when plugged back in it spikes the internal power and shuts down.
lyrad I had the same issue but an update was pushed to my SBV and since then it 8s much more reliable
footmansolar The Superbase V shut down and trips the circuit breaker when I turn on AC while charging from the grid. It doesn’t happen when using solar to charge.
utlize I have updated everything. Still shuts down under load . It isn't allowing to power through. I have it plugged in and shuts down when I plug in the fridge
