The SBV shutting down AC output when fully charged is actually a bug which they have tried to mitigate in a firmware update several weeks ago. However it isn't fully fixed and is still occurring every few days at least on some devices. As a workaround, setting the maximum state of charge limit to 97% usually helps. This in turn might lead to inaccurate state of charge reporting, and the issue may still reappear, so it clearly isn't a good final solution, but I hope that one day the developers will learn how proper battery management works and will fix the underlying firmware bug. I've sent them a detailed report of what the root cause of that issue is and how it can be fully fixed, but I haven't heard back about this for several weeks now. Some way to allow AC input to only be used when the battery is running low would also be great and they promised in an email that this would be implemented later this year, but I'm not very hopeful that they will get that right, given all of the other battery management issues. The real killer in the comparison to EcoFlow's approach is that the SBV can't be used with a grid-tie inverter, and I don't think that will ever change. It would require the introduction of an SBV-specific grid tie inverter, which requires a lot of certifications, which they obviously didn't even want to bother with for SolarFlow, sacrificing a lot of efficiency and risking compatibility issues. We've seen how that decision played out.
