ravi Hi guys, does anyone have the the official power efficiency figures, when charging from the AC outlet.. I charged up from 75% to 100% and 3.3kwh was taken from the grid... Seems a little high considering only 2.2kwh was pushed into the battery.
rex soc percentages ar not that accurate, at least not in the beginning. you will need multiple charge cycles to get some accuracy. Also try to measure with an external device. rough estimates isbabout 80% charge efficiency via AC. but actuall efficient varies according to input power and if there are also devices using power from the SBV..
