hageney@gmail.com While setting up the SolarFlow everything works, except the WiFi connection. I’ve tried the 2.4 and 5 GHz networks about 20 times, no chance. With the phone navigating online (with WiFi) the Zendure app doesn’t connect. What can I do?
Beppi Stardust I did try as often - but one solution working for me was to allow WIFI encryption WPA2 only.. You even should’t use a WIFI password including the “,”.This was posted before by a Zendure supporter. In my case it did help to use airplane mode with enabled WIFi and Bluetooth on my Iphone.
Nockl Disconnect all cable, wait for 15 Minutes and then reconnect all cable. After that everything should work fine again. Best Regards from Germany 🙂
