henrideath Hi, I also experience the AC shutdown completely randomly just had it at 43% please resolve this quickly or at least let us bypass AC as in no charging when connected to the power plug unless charge is under x% (and let solar flow through whenever available. This will potentially cause harm to the connected devices. Thanks
henrideath Ideally this is what I think should be relevant as an option... Power input no charge unless under 10% if cheap electricity, plus charge anytime if under 5% and set a stop charge threshold
theseven Did it show any error codes? Shutting down at this state of charge is weird, the common issues usually happen at very high or low state of charge.
GCustom It's quite common for mine the thing is always shutting off at random with full or plenty of charge remaining regardless of the settings
Belec54 Hi, same problem with my SBV 6400, the support is working on it by checking logs and update firmware but no enhancement for now. It s not reliable…
