Solarpower Dear Zendure Team, will there be a product coming enableing the SuperBase V as Storage for the SolarFlow. There are similar offerings by competitors and the demand is definitely there. Best regards, Daniel
primdigital Why not instantly charge the super base V on the AC side using micro inverters on the panels. The super base thinks it’s connected to the grid and uses the battery when there is no sun?
theseven Because the SBV's charging can't be controlled like that. That one will charge whenever it has input power available, i.e. as soon as it is plugged into the grid.
primdigital What would you like to control? When you put it in slow charging + UPS what would be the issue? It has a dedicated grid from solar and UPS kicks in by clouds. Battery at night
