My understanding is the SuperBase V4600 has 3KW pure sine Inverter.. which will probably deliver poor efficiency in low loads ie.. less then 1000w.. possibly 80%, so a 20% loss! I am mostly using around 300 - 350w load (PC and TV)
Is it possible to hook up the Satellite B4600 Battery to a Victron battery charger and Inverter? My ideal would be use the V4600 for bigger loads ie, kettle, toaster, Air fryer, washing machine, DIY tools etc and use the satellite B4600 as standalone with a Victron inverter for small loads to maintain a high efficiency %
Any idea on what's cables would be required for the Victron inverter / charger.. and what output port to use on the B4600 please?
Thanks
