Jinso Right now, if the bypass is manually disabled, from app is safe to use 800 watt panels (2x 400 watt peak) on 400 watt micro inverter? (If the battery reach 100% there is no risk for the micro inverter?) Thx in advance, Regards
Jinso Not work more you mean that has problem or it just doesn’t accept more solar input until battery go below 100%?
Ralf [unknown]Hallo SolarflowSpatz, Darunter verstecken sich nur die Alkus. Hub und Wechselrichter sind weiter oben montiert.
