Leerstelle Hi, is the network port of the sbv working to connect it by LAN to the network? And does it provide POE? Thanks Jens
rex and it is used on the 120v (us version) when you join 2 SBV units together to obtain 250v split phase.
alexfi @rex how do you set that up? I joined to sbv4600s together today with a rv plug, tested their voltage at my combined plug and i would get stable 240v when they didnt have their 120v ac charge cords plugged into the wall. When they were plugged into AC input then the phase of the output wouldnt stay balanced. Could i use the lan port to keep their split phase synced even when charging on AC? How would that look?
theseven It is a CAN interface used for coordination between the inverters of 2 SBVs in a home panel setup. Not sure if it could be used interface with the rest of the SBV in some way.
theseven If they stay synced on battery power, then they are working as intended. When charging, they pass through what you supply to them on the AC input, so make sure that they are on different phases.
rex the communication cable should come from zendure together with the zenY cable. provably the software or settings too. i do not have further info on this i have an EU version of SBV. maybe ask zendure support for
