Instead of waiting for my ZenY cable, I decided to test the 240v/6-20 outlet to my Reliance R310A manual transfer switch. I don't think the SBV4600's neutral is bonded to ground or the chassis, so this pairing should work?
Well I tried turning on 1 simple 120V circuit and nothing happened, no power draw at all from the SBV. I made sure AC output was on. I tried 3 smaller circuits on the transfer switch with no success.
Has anyone gotten their SBV to work with a transfer switch? Reliance tech support said this should work unless the SBV or generator is GFCI protected. One caveat, I also tried to use my EV (120v/1800 watts)to power the transfer switch and that didn't work either.
Any ideas?
