21232f297a57a5a743894a0e4a801fc3 Hi there, got a huge Problem with the ac output when i use the special mc4 to ac adapter cable. It shuts off..! So i cant use both, it will only load the battery.... Anyone knows how to fix that? Firmware was updated yesterday...
theseven The SBP doesn't support AC input while charging from solar through the AC port. And with 1kW worth of solar you can't use the XT60 input either. This is documented in the user manual.
21232f297a57a5a743894a0e4a801fc3 Will have to refund it... Sbp 1500 also cannot use ac and dc input at the same time!
theseven While I don't have one, I think AC and DC input should work at the same time. I remember them explicitly mentioning that combined charging power somewhere.
israndy That is correct, the Superbase Pro can handle AC and XT60 DC input at the same time, no problem It is just the Solar in via the AC input port that causes the AC output to turn off until the charging is finished.
