Batteriekabel OHNE MONTIERTEM Stecker
Hello Zendure Techis,
is there a posibility to buy one of the 5m Batterie cabels with just ONE connector applied on the cable.
To pass the wooden window frame with a smal hole, diameter of the cabel, NOT the thick connetor, i need a cabel where i can mount the second connector AFTER passing through the window frame.
The cabel wires will be applied to the connecter according wire scheme.
Or is there a mode to disassemble the connector without destroing it ?
Thank you for assistance in advance.
Regards, Wolf
