Hi all,
my SBV is set up to charge the battery to 80% by AC power. And I have always running some devices at the AC output. So the SBV is running in UPS mode and it should passthrough the AC power from grid.
But I see now that the SBV is permanently charging and discharging the battery. Is this a normal behavior? When there's a passthrough of AC power it shouldn't permanently charging and discharging the battery, right? Or is this because of an unstable AC power voltage in the AC input side and the SBV delivers always a stable AC power voltage on the AC output side? So the battery is charging and discharging at the same time?
Then it's no problem for the battery lifetime when I will change the power input to DC only so that the battery is charging and discharging at the same time? Until now I thought that it isn't good for the battery when it's charging and discharging at the same time for a long while.
Kind Regards
