Hi all,
the rubber bands of the output doors aren't good. On the DC output the door can't be closed or when you have closed it opens itself after a while.
On the AC output the lower rubber band isn't fixed anymore at the door. And I can't get it fixed anymore. I don't see if it should be glued or if it's only stuck in the little plastic nose of the door. How can I get this repaired?
Zendure, you should change the design of the doors protecting the outlets.
Kind Regards
