Hello,
I use two Hyper 2000 units in off-grid mode.
When solar production is higher than the load (for example 700 W PV and only 100 W AC load), the Hyper 2000 still cycles the battery with small charge/discharge operations.
I would like to request a true PV bypass mode for off-grid operation:
Solar panels should power the AC output directly whenever possible.
The battery should only be used when PV power is insufficient.
This would reduce battery cycling, improve efficiency and extend battery life.
Many off-grid users would benefit from this feature.
Is this planned for a future firmware update?
Thank you.
