kneko During charging my SBP1500 via vehicle cigar socket, vehicle 15A fuse has blown. So I replace the fuse to new one, however fuse has blown again. I want to limit the charging current to 10A. How can I do that?
support Charging of devices via XT60 at 12-60V and 10A, device cannot be set, try a different way of charging.
byjehan Same issue, cigarette plugs heats up fast, then 12 amp fuse blown. If it's limitable like ac, this will solve issue. Need firmware!!
riivor +1 on this feature request. Limiting DC would be quite beneficial when charging from other batteries or car.
ZenUser13es5Bwr [unknown]The problem is when it discharges to 40%. It stays there and never charge again. This system is broken. You can not control nothing.
