I wonder how much of this is explained from AC inverter power loss. Leaving the AC power output on overnight can drain nearly 50% of the SBV 4600! Of course, you can and should set an automatic turn off, but it still a lot of power loss! I recommend buying a cheap AC inverter that plugs into the DC car output to run small AC loads without having to worry about half your battery draining for no reason!
