ZenMickeyBelgium Bonjour, je viens d'acquérir un Zendure 2400 pro malheureusement impossible de le configurer sur le réseau belge. Y aurait-il quelqu'un qui pourrait m'aider ?
alex7b Have you installed the latest firmware? Do you have an error code? In case of code 40 (ground fault), the battery has the option dual live wire compatible switch in the settings.
ZenUser297aYvha If Belgium cannot be selected, then first choose Germany, next upgrade the firmware. After that you should be able to select Belgium
