Hi,
I have the same issue with two Hyper 2000 units using ZHA.
In the evening, the batteries are not being used to fully cover the house's power demand.
I modified the files as suggested (thank you) , but the issue remained.
Today, I tried disabling energy export to the grid, and now everything is working fine.
So:
If grid export is enabled → bad behavior
If grid export is disabled → works correctly
Has anyone else experienced this or found a solution?
Thanks!
