ZenUser2563BB1V Accu states 100% charged while that is not possible. See the graphic below, the accu goes to 100%. Any ideas?
ZenUser12WG15cM If your battery capacity is 2.14kwn, it can become full in less than 1 hour when you turn on 2400w
ZenUser2563BB1V It is a Solarflow ac2400+ with 1 extra accu, so the capacity is 5,2 kwh, so how can it be full with so little charging?
zzZ ZenUser2563BB1V you are watching the wrong data. The SoC statistic is trash. Mostly incorrect. You must watch the voltage data of the batteries. Then you can see that your batteries are working normal.
