ByteBuster I opened the app, and 1 of the 5 battery's is gone. API call shows also 4 of 5. How can this be fixed? I shuffled the battery's, without succes.
ZenUserFJMB Please check your connectors between batteries and 2400AC. There are issues with people reporting burned connectors. Which battery disappeared?
KlaaZ Is there a code 46 error sometimes? I had this too. One of the battery connectors was installed incorrectly in the factory and therefor didn't make good contact. It had a burned connector and damaged the inverter above it.
