Dears, i am using HUB2000 since more than 2 years and very satisfied. My system elements are as following;
6x450W Trina PV, installation is 2x2PV parallel and other 2 PV single.
4 PV direction to East other 2 West.
2 times, 2Parallel connected and 1 single PV connected to each HUB2000 inputs. ( Naturally secured due to direction to west and east)
I have 2 AB2000 battery connected to HUB.
As last element I have Hoymiles 1000W-2T microinverter, working 800w outlet power.
I am planning to add additional HUB2000 into the system to relax working conditions, HUB is getting very warm all day.
As you can imagine 3 PVs (1xparallel connected +1 single PV) to HUB1 and same to HUB2.
And 1pc AB2000 battery to each HUB.
Additionally i want to change the microinverter with a bigger one, maybe Hoymiles 2000W, not yet decided, this is also to relax it because it works almost at the max limit.
Would be great if you can let me know comments.
And last but not least, when teo HUB2000 are working together, can Zendure HUB properly manage the system.??
Thxxx
