ZenUser25BRN0cM Hi everyone, I cannot delete the Smart Meter (Shelly) from the App as it says that there is a Connection Problem. Has anyone encountered this as wel?
Surfer1264(2nd) Remove the Shelly Connection completely in the Zendure App Not only removing device ….this doesn’t work
Tim (Moderator) Hallo. Hast du mal die Shelly Verknüpfung aus der Zendure App gelöscht (nicht nur das Gerät)? Dazu die Verknüpfung unter Profil aufheben. Anschließend neu verknüpfen. Versuch das mal. Es gab seit gestern mit Shelly Probleme. 🙈 Gruß, Tim.
DaSamy Remove the device from shelly, then it disappears at zendure too. i had the same issue with a Gen 3 plug which is supported too. I integrated an old Plug S and it worked...
ZenUser191pMj3b DaSamy Jes usually that is working but not yestarday for almost 24 Hours. Cloud was not working correctly and it was not possible even when logging out from the Shelly cloud. Was fixed luckily yesterday night
