I want my Zendure to function as a UPS. Problem is, when plugged into the wall with the AC inverter set to on, my Zendure drains. I have go into to app and turn AC off, turn back on, to get my v4600 to start charging. This every few days ??? Firmware is current.
Update: FYI. I set my charging limit manually to 400W. I am now observing a continual 150+-W both in and out. If the V4600 goes down to about 98%, the input charge goes up to about 300W and tops off V4600 and Satellite battery without incident. It has not kicked itself out of AC Inverter mode and seems to be functioning correctly as a UPS.
