Dear Zendure Community,
With the ongoing changes to feed-in tariffs and solar panel installation policies, you’ve likely realized just how important it is to effectively store your generated solar power.
The SolarFlow Mix Series brings a comprehensive upgrade to both PV input power and input pathways.
■ SolarFlow 3000 Mix AC+: Max. 3,000W PV input
■ SolarFlow 4000 Mix AC+: Max. 5,000W PV input — features a PV-IN AC port (Max. input: 5kW)
■ SolarFlow 4000 Mix Pro: Max. 13,000W PV input — features an 8kW MPPT + PV-IN AC port (Max. input: 5kW)
** New PV-IN AC Port: Directly connect third-party solar inverters to the device, allowing you to utilize your rooftop solar power even during an off-grid power outage.
What do these upgrades mean to you?
■ A higher PV input ceiling and faster charging speeds to capture and store more of your surplus solar energy.
■ During a blackout, you can still connect third-party solar inverters to use your rooftop solar off-grid.*
■ Dual input channels provide much greater flexibility for system retrofits and installations.**
Note: *SolarFlow 4000 Mix AC+ & SolarFlow 4000 Mix Pro; **SolarFlow 4000 Mix Pro
Wishing you a day full of sunshine! ☀️
Your Zendure Team
