Dear Zendure Community,
In your daily life, you've likely experienced the limitations that power output places on household electricity use.
Without changing its "plug and play" convenience, the SolarFlow Mix Series has achieved a breakthrough in power, capable of covering more high-power household loads.
■ SolarFlow 3000 Mix AC+: 3kW bidirectional AC power
■ SolarFlow 4000 Mix Pro & SolarFlow 4000 Mix AC+: 4kW bidirectional AC power, with output reaching up to 5kW in PV passthrough mode (via the PV-IN AC Port).
What does higher bidirectional AC power mean?
■ Worry-free operation of high-power appliances: Refrigerators, stoves, washing machines—even during evening peak hours, they can run simultaneously.
■ Realize electricity savings: Covers power demands during evening peak hours, avoiding the need to buy expensive grid electricity at peak times.
For what kind of household is this most meaningful?
■ Households with multiple high-power appliances that want to cover a single high-load circuit as completely as possible.
Wishing you a day full of sunshine! ☀️
Your Zendure Team
