Dear Zendure Users,
The SolarFlow Mix Series is Zendure’s innovative solution in the field of plug-in energy storage.
With breakthrough ingenuity in both its exterior design and performance, it aims to offer you a wider range of versatile options.
Read this announcement to quickly discover the core highlights of the SolarFlow Mix Series ↓↓↓
High-power PV input, Full-path PV integration (PV-IN AC port)
■ SolarFlow 3000 Mix AC+:Max 3,000W PV input
■ SolarFlow 4000 Mix AC+:Max 5,000W PV input —— Built-in PV-IN AC port(Max input:5kW)
■ SolarFlow 4000 Mix Pro:Max 13,000W PV input —— Built-in 8kW MPPT + PV-IN AC port(Max input:5kW)
** New PV-IN AC Port: Connect third-party PV inverters directly to the device, allowing you to harness rooftop solar energy even during off-grid power outages.
Greater Bi-directional AC Power, Breaking Conventional Single-circuit Output Limits
■ SolarFlow 3000 Mix AC+: 3kW bi-directional AC power
■ SolarFlow 4000 Mix Pro & SolarFlow 4000 Mix AC+: 4kW bi-directional AC power, with output reaching up to 5kW in PV passthrough mode (via the PV-IN AC Port).
8kWh Single-unit Capacity, Expandable Up to 50 kWh
■ A single unit stores 8.038 kWh, easily meeting a family's daily electricity needs without requiring multiple expansion batteries.
■ SolarFlow 4000 Mix Pro & SolarFlow 4000 Mix AC+: Support up to 6 external 7kWh expansion battery packs, expanding the maximum capacity up to 50kWh.
High-efficiency, Durable Battery Cells: A One-Time Investment for Long-Term Returns
■ Features a long-life battery solution with 10,000 life cycles (SOH=70%) and a 15-year lifespan.
■ 90% RTE (Round Trip Efficiency), ensuring higher charging/discharging efficiency and improving real storage returns.
Powerful Off-Grid Output, Meeting Both Indoor & Outdoor Needs
■ 3680W off-grid AC output, with a peak performance of up to 7200W (200ms).
■ 10ms UPS Switchover, ensuring a seamless, uninterrupted emergency power supply.
Easy Installation & All-In-One Environmental Resilience
■ Continues the "Plug & Play" philosophy for effortless grid-tied installation.
■ IP65 dustproof and waterproof / wide temperature tolerance from -20 to 55°C / 25dB quiet operation / robust metal shell.
Discover more information about the products here ↓↓↓
Forum: Head over to the #SolarFlowMixSeries section
❓️ Which product feature are you most curious about and want to learn more about?
Share your thoughts with us in the comments!
Wishing you a day full of sunshine! ☀️
Your Zendure Team
