8kWh > 7kWh
On paper, the difference between 8 kWh and 7 kWh might seem minimal.
But for households trying to cover evening peak usage and overnight base loads, this single extra kilowatt-hour often makes the difference between a battery that drains completely by midnight—and one that smoothly powers through until morning.
A standalone 8kWh capacity provides a significantly larger energy buffer after the sun goes down.
For homes with solar storage, this means:
More of the energy you generate during the day is available exactly when you need it most—at night.
❓Is your current storage system enough to get you through the night? Or have you already upgraded to a larger setup?
Let us know in the comments!
