ZenUser18ma730J Hi all, Issue I have is that the battery is charging fine, but never discharges. Typical load during the night is between 50 and 150W. Am I missing something? Thanks for any suggestions 🙂 Some specs: I use HEMS Hyper2000 + battery + P1 meter no automations via Home Assistant Using Smart Meter Mode Monitor device (P1 meter) is active and shows the right values. Start AC charging is enabled AC charge time is set to "Follow the surplus power"
ZenUser14pLXbQ Hello, Try to use General - Auto mode instead of smart meter mode. In this mode the controller will follow the P1 meter.
ZenUser18ma730J Thank you. I have used Universal / Auto mode for a couple of days, but I still not seeing any output from the battery. I also have rebooted the Hyper2000 to be sure, but no luck. If there are other tips, would be appreciated. 🙂
ZenUser18ma730J Resolved it, pretty silly... Circuit breaker had tripped for the group which also had the zendure on it. Thanks anyway!
