108 How can we adjust the fan speed? It's getting summer and even now the unit shows the temperature too hot for the batteries.
support Sorry, the fan speed, cannot be adjusted by yourself. If the unit is overheating, it is recommended to let the unit cool down for a while before using it again. Have a nice weekend.
108 Could you fix that with an update? For example having 3 settings, auto, low and high speed rotation.
Micha83411 at low load, the fans go on and off, if you could regulate yourself in this area it would be good, maybe 300 rpm at 400 watts. and the fan control is too rough and immature. at 500watt on off on off ....
