From entry-level to flagship, Zendure offers the industry's most comprehensive product lineup. The new SolarFlow series continues Zendure's strong compatibility, providing you with an unparalleled energy storage experience ↓↓↓
HEMS 2.0 Integrates Multiple Systems for Intelligent Scheduling
If you have multiple properties or a high electricity load, Zendure HEMS 2.0 will integrate various systems for intelligent scheduling, making it a worry-free choice.
(1)What is HEMS?
HEMS (Home Energy Management System) is a comprehensive “home energy brain” that connects photovoltaic, storage systems, the grid, and electricity loads through software and hardware. It continuously collects data (power generation, electricity usage, electricity prices, battery status, etc.) and automatically schedules based on pre-set strategies, making home energy use more efficient and hassle-free.
(2)With HEMS, you will be able to:
🔹 Configure independent HEMS for multiple homes, managing up to six devices under each system, making it easy to handle energy scheduling for multiple properties and loads.
🔹 Let the system automatically manage energy without constantly monitoring electricity prices and generation.
Don't miss out on detailed function explanations ↓↓↓
Self-check path: Zendure APP --> Forum --> Beginner’s Guide --> Product Manuals --> Zendure HEMS User Manual
Compatible with Heat Pumps & EVs, Creating a High-Power Energy Ecosystem
If you already have or plan to install a heat pump or electric vehicle, Zendure will be compatible with these high-power devices, achieving ecological synergy.
🔹 For heat pumps: You can utilize surplus solar energy or low-cost electricity for preheating, significantly reducing heating costs.
🔹 For EVs: You will charge your EV economically and environmentally, at the lowest cost and carbon footprint.
Integration with Smart Home Platforms for a Personalized Experience
If you seek a personalized smart home experience, Zendure is compatible with smart home platforms like Home Assistant and Homey through the MQTT (Message Queuing Telemetry Transport) protocol!
You will gain:
🔹 Unified monitoring and automation of devices using popular smart home platforms.
🔹 Freedom to customize energy scenarios, enhancing convenience and comfort in your life.
No Need to Replace Smart Devices, Easy Compatibility with Major Brands
If you want to connect existing devices to HEMS 2.0 without replacements, Zendure is compatible with multiple smart device models from brands like Shelly, EverHome, and Homewizard.
You will enjoy:
🔹 Direct use of existing smart devices, reducing the need for additional investment and lowering the usage barrier for Zendure's main unit.
100% Compatible with Mainstream Rooftop PV Inverters
Zendure’s AC-coupled energy storage devices are 100% compatible with mainstream rooftop PV inverters, providing millions of households with installed rooftop PV systems but without storage, the easiest upgrade path.
You will benefit from:
🔹 No need to replace existing PV inverters, reducing initial investment costs and installation complexity.
🔹 Existing PV systems can achieve a simplified upgrade, creating greater value.
New Products Easily Compatible with Previous Battery Models!
SolarFlow 2400 Pro
🔹 Compatible with: AB1000/AB1000S/AB2000/AB2000S/AB2000X/AB2000L/AB3000L
🔹 Recommended: AB3000L; other models are not recommended due to size incompatibility.
SolarFlow 2400 AC+
SolarFlow 1600 AC+
🔹 Recommended: AB1000/AB1000S/AB2000/AB2000S/AB2000X/AB2000L; other models are not recommended due to size incompatibility.
Note: If choosing a non-recommended combination, please carefully assess spatial and environmental conditions in advance. After-sales support coverage may be limited for issues arising from non-recommended configurations or usage environments.
More Information on New Products ↓↓↓
SolarFlow 2400 AC+: https://zendure.com/products/zendure-solarflow-2400-ac-plus?utm_source=APP&utm_medium=forum&utm_campaign=EN
SolarFlow 2400 Pro: https://zendure.com/products/zendure-solarflow-2400-pro?utm_source=APP&utm_medium=forum&utm_campaign=EN
SolarFlow 1600 AC+: https://zendure.com/products/zendure-solarflow-1600-ac?utm_source=APP&utm_medium=forum&utm_campaign=EN
Your Zendure Team
