Title: Zendure V4600 does not detect Satellite Battery (LED on, no expansion detected)
Post:
Hi everyone,
I’m having an issue with my Zendure SuperBase V4600 and Satellite Battery and I’m looking for advice from anyone who has experienced this before.
Situation:
• Main unit (V4600) powers on and works normally
• Satellite Battery shows LED (it powers on)
• Expansion cable is connected properly
• However, the V4600 does NOT detect the Satellite Battery
• Satellite does not appear in the app and capacity is not added
• No error code on the screen
What I have already tried:
• Powering off both units completely
• Disconnecting the expansion cable
• Waiting several minutes before retrying
• Turning on Satellite first, then main unit, then connecting the cable
• Long-pressing the Satellite power button to wake it from sleep
• Using the original Zendure expansion cable
• Resetting the main unit (without Satellite connected)
Result:
• Satellite LED turns on, but there is no handshake / communication with the main unit
• It looks like the Satellite is awake but the BMS is not establishing data connection
Question:
• Has anyone seen this before?
• Is there a specific reset procedure for the Satellite Battery BMS?
• Could this be a firmware mismatch or expansion-port cache issue?
• Any confirmed fix before contacting Zendure support?
Thanks in advance for any help or ideas.
