Do you have many accounts ?
And if yes which account do you use for ZHA?
Use always the first account ! The account which you used to register the hub.
Which hub ?
The originally problem with the token was solved.
Which version did you install?
I guess you need to install the latest PRE ( and not the officially released one 1.1.3)
On all three systems, token-based login works (I've only tested version 1.1.4-pre10 so far).
If you have further problems go to the service page of ZHA and open an issue
https://github.com/Zendure/Zendure-HA/issues
Before that look through here
https://github.com/Zendure/Zendure-HA/issues/915
If ZHA couldn’t help open a service ticket here
https://support.zendure.com/portal/en/home
I guess you won’t get help here in this forum for this special case.
