Hi,
This happened already several times where of course I am not home and for no reason the sloarflow 2400AC got disconnected. I am able to connect to my home and I can verify that my WiFi and network is working as expected. To make it online again, I was not able to do it remotely, which is a big issue when you are far from home. I don’t know if I am doing correctly. So far once back home, I try to remove the power cable from the wall outlet but didn’t come back online. By pressing the button for longer time that the default time to reset/ set WiFi make it (I think) shutdown. Once I plug it on again it restart and then the WiFi connection was back online. Did I do it correctly? Is there a way to make it to reconnect to the WiFi on its own. Last time not been home made the battery to discharge completely. Thanks
