ZenUser24VPdCrA I have a mono system. I have put the Shelly 3em pro with the phase of house in C, the first solar system in B and second solar system in A. When I had the Shelly 3em pro, zendure add the 3 phases ( and make a wrong addition). I would like to select only phase C to monitor and drive the solar flow. How to select the C only? Thank you for your help
ZenUser27W6nUbs I have the same problem, and it's probably a known problem not yet solved by zendure team. I have disconnected the 2 others cables and it's ok. I'm waiting for the fix in a next version of firmware....... Best regards Hervé
JulienZen Bonjour, Perso, la pince C au niveau de la phase général, mais donc si je comprend bien, je peux branché les phase restante sur la partie solaire ? Comment cela ressort t'il sur l'application Zendure ? cela ne pause pas de probleme particulier ?
