Thanks for the comment!
The problem was solved, but in a slightly different way. By holding the ACPower Button for a long time, the mode was switched and the Home Panel indicator on the display disappeared. A separate question is why it is active at all if I did not activate it 🙂?
As a result, the output current sockets worked in the previous mode. If only the manufacturers heard the words I used to remember their developers 🙂
