Hi, when I see it correctly you posted today having problems with Shelly Pro connected with AIO2400, right? Have also problems. Have also AIO2400 connected with Shelly Pro 3EM (120 Amps). In Smart-CT-mode AIO pumps nonstop full 800W into net totally independent if power is needed or not. At a sunny day no problem and I support our energy network pumping all in but when it is cloudy it vontinues to pump energy into the net USING battery power (uncharging my battery until it is empty. This shouöd not be, right?
Perhaps sonebody had similar problem solved finally?!
My system is installed since a few weeks
Looking forward to receivibg a reply. Thanks a lot
Detlef
