ZenUser2207B4e1 For the Day my 2kwc instal with hyper2000 and 2 ab2000 is limited to 118w. It works perfectly everydays but today there something wrong as there is sun so I should be more than 1kw... I trier restarting but didnt work. Any idea? Thank you!
ZenUser62871M3 Eventuell zu heiß geworden? Dann begrenzt der Hyper dir Ausgangsleistung. Wobei bei nur 100w wär das schon etwas extrem.
solarbier can be the thermal protection 🤔 in that case the hyper reduce the outputpower if you using HA integration or can read the mqtt data, the internal temperature values of your hyper and each battery is reported.
ZenUser2207B4e1 Thank you for your comments. I reboot my box and then everything went right. Today it worked properly and the batteries are full.
