ZenUser22aU14XD Do I need to do anything other than connecting the base to the satelite battery to make it operational? The app shows the two units connected but as soon as the base gets below setpoint everything just switches off. Is the satelite supposed to kick in?
rex All devices turned off, connect satelite to sbv, turn sbv on. Satellite should start by itself. Add to the app if needed as connected to sbv not standalone. Follow instructions.
ZenUser22aU14XD Thanks Rex, appreciate the help. I can connect bothe devices to the app the issue is the SBV will discharge but the battery wont. For reference im using a 1500 watt ceramic heater connected to 240v outlet on SBV. Should bith units be discharging at the same time?
FF Yes satellite should discharge too. Is the little satellite icon shown on display of the SBV? If not repeat what rex wrote.
