Hello,
I would like to increase the electricity production of my balcony photovoltaic system.
The system currently consists of: n.1 HMS-800W-2T Inverter, n.1 Solarflow 1200 Hub, 2x AB 1000 batteries and 2x jolywood 340 watt solar panels.
The Jolywood panels are each installed on its own MPPT, and have the following technical characteristics:
Current at Pmax (Imp) = 9.70 A
Voltage at Pmax (Vmp) = 35.1 V
Short-Circuit Current = 10.17 A
Open-Circuit Voltage (Voc) = 41.8 V
I would like to install 2 more panels to increase the efficiency of the system.
These 2 new panels, of the flexible type, 240 watts, have the following characteristics:
Current at Pmax (Imp) = 11.23 A
Voltage at Pmax (Vmp) = 19.60 V
Short-Circuit Current = 11.90 A
Open-Circuit Voltage (Voc) = 23.60 V
I would like to update the system by putting a 340 watt panel and a 240 watt panel in parallel on each mppt.
Do you think a configuration of this type is possible on the Solarflow 800?
Thanks for the help.
