Davidlhs Hi, i need help, my superbase v4600 was at 80%... Suddenly discharged to 0%. Now the app have a freezing temperature sign on the top right corner n its no longer charging up
rex calibration probably required. Completely discharge till it automatically disables AC OUT. recharge via AC IN while no output is enabled on the SBV. perform dischage and recharge at constant rate
lando4k2 I have the same problem since two or three days. Full reset doesn’t help while every in/output is plugged out. Charging via AC or DC doesn’t work. I opened a case at Zendure and sent them serialnumber of the device and a video. Let’s see what happens.
