Igor Hello everyone Have you seen such a case ? Battery was charged fully at around 12 and from that moment solar output was limited to 1k - plat line on the screen shot
Igor Stefan thank you for the suggestion. I own hoymiles HMS 2000 4T. It's captable to handle 650+W on a single input . However, who knowns ...
PV-Laudi Die Leistung wird auf das eingestellte Limit + das was an Wandlungsverluste + Betriebsstrom (für den Hyper) reduziert. Hast du die Einspeisung ins Netz verboten wird die Leistung weiter reduziert sodass nur der aktuelle Bedarf gedeckt wird.
Igor Does it mean that the value I see 1070W is nett maximum ? 1200W is max device output that is reduced by conversion losses and by energy needed my hub2000 ?
Igor Thanks, Indeed I have had output set to 1000W. I set it to 1200W. I'll observe the system and come back with new observations
