I have the suggestion to add an option "battery first" to the existing energy plan "Smart CT mode".
I have a Hub 2000, APsystems microinverter, 2 AB200, 1 ACE 1500 and a Shelly Smartmeter.
I like to use the energy plan "smart CT mode" but also want to have enough energy in my batteries for a blackout or other emergency. But with the "smart CT mode" I cannot store energy in my batteries.
Would it be possible, if you add an option to the "smart CT mode" like "battery first"? That means, that the system stores energy into the battery, until it reaches the maximum SOC (or 90% of it)?
I tried to use the minimum SOC and set it to 50% (thats the maximum), but the thing is, that I cannot use it for emergency, because if the grid power is gone, the WIFI is gone and I cannot reach the ACE or HUB. When I try to add the HUB or ACE with Bluetooth, I always need to be connected to a WIFI - otherwise it does not work with the error message "Network connection exception". And without reducing the miniumum SOC I cannot use the energy in the batteries to discarge energy.
